How speed pro users controlling the lockup
Pittman
what about this???
1) put the factory computer back in
2) use a single pin connector to connect the VSS (DRAC) to factory box
3) single pin connector back to TCC solenoid.
4) single pin to the 12v input.
So basically your hard wiring up the factory computer to do nothing but operate the TC. I have a pin map of the factory unit and know I can do it. The question is will it work? I dont know the logic of how it operates. If its mega primitive as I think, it should work. What was factor lock up 45 or so?
smeagol
there is a B&M controller that has a little slider to select what mpH lockup occurs at - best for tuning & drivability
or put a switch, put a switch & hobbs switch also... other wacky combinations.
130-70244
GM Automatic trans w/lockup converter and mechanical speedo cable
$161.99
130-70248
GM Automatic trans w/lockup converter and electronic speedo (exc. Berlinetta, ’84-’86 Firebird)
$161.99
(you want the electronic speedo version)
FLSY2730
I just use a toggle switch but i might try that bm down the road, dont drive the truck enuff to worry about it.
At the track I just lock it up on the line and when it shifts into 2nd it is locking up, what a rush it is also having hartmans tranny and lockup.
I might try locking it up at the top of 2nd or bottom 3rd.
The bm sounds like the best way to go, has anyone used that ?
keith455
Average Joe
Staff member
I have the B&M in my 75 Hurst/Olds (200-4R Tranny) and it works really well.
In my SY I saved myself a bunch of money and just put a toggle switch to the TCC.
BigAl...
I've been using the B&M setup since I installed the speedpro, it works like a charm and is very easy to install. To set it you simply drive to what ever speed you want the tc to lock up and turn the knob until the light turns green and thats it.
BigAl...
Nick Stephens (T66 Typhoon) has one for sale, check with him
FLSY2730
BigAl...
Al, i going to have to try that kit, how much did you pay for it, how is your sy doing?
Do you have the vortecs on now and bigger cam, what turbo?
Have you been to the track, we need to hook up at moroso soon.
BigAl...
hey Jack, the kit cost about $160 through jeg/summit but like I said T66 Typhoon has one for sale and he wants less than that, it really does work like a charm. Truck WAS doing great 8) until I took it apart :eek: , dropped off the block at the machine shop yesterday should be done in a week OR SO! :roll: Yeah, it's going back together big cam big heads big turbo
BigAl's law of relativity Big = expensive
BigAl...
G
Guest
Guest
I have a 70248 hanging down in the garage, and it has been tested. I now have a non lockup TC, so if anyone is interested in it, I'll let it go for $110 shipped to your door.
****SOLD TO SANDMAN*****
I'll take it - send me payment instructions.
GEN3Typhoon
I have one of these also.. brand new..I will sell it for the same amount to someone. Too bad I did not get in on this earlier..
Al.... WHAT ARE YOU DOING? I will call you this week.
GEN3Typhoon
I went the the eletronic transmission.. and the controller that Hartman sells... NO MORE TV CABLE.. YIPPEEEEE and no more need for the controller.. the TCC lockup is controlled by the new tranny computer.
