How tight do I install the new knock sensor?
mrweelr
I'm going to install my new oil pressure sender and knock sensor today and I don't know how tight to turn the new knock sensor. Can someone look up the procedure in the Sy/Ty service manuals and tell me how tight it should be. I doubt if I'm supposed to use a torque wrench on this thing and I don't want to overtighten it. Anyone got the specs?
Thanks :wink:
4C FED
Absolutum Dominium
Re: KS torque specs
Re: KS torque specs
kwick6 said:
14 ft-lbs
Scott
I think you loose like 25% accuracy (correct me if wrong, please) below 50% of the wrenches max. torque.
Use a in. lb. (if they go that high) or one with a low range for best/most accurate readings.
mrweelr
There was no room to get a torque wrench in there so I just did it by "feel". Gonna' take her out for a Datamaster run now to see if it helped at all; not likely but worth a try. At least my oil pressure gauge is sitting pretty at 60 psi now :D BTW, I had to pull the distributor to get those two sensors out. Marked everything and set the timing back to 0 with tan wire disconnected and we're good to go.
