How to Clean IAC?
syntax
are there any tech articles on how to clean the IAC? what cleaner to use? ect ect? pics? thanks for any info :O)
Ian Turgeon
Cascading Inspiration
When I did mine, simply remove the throttle body (you may concider getting new gaskets for re-installation)
the iac is bolted onto the tb, you can seperate, clean everything out using tb cleaner. Worked pretty simply on mine and a buddies
just a 6
R.I.P MyClone
Re: How to Clean IAC?
Brake cleaner and a tooth brush makes wonder :D
Coloty
I used Intake cleaner (less harsh than brake fluid, but the same idea) and a toothbrush.
Mad Mike
SYCOSIS
You can remove the IAC with a 22mm deep socket ( I think that's the size). Then clean it with CRC electronic cleaner.
tealty
Yeah, just be sure you dont get any carb cleaner in your eyes when you spray it. That shit burns and makes your vision blurry for about an hour.
later
Jordan
