grandam75
My engine had a severe main bearing faliure. After the buidup I had to take it apart again to correct a problem and found a lot of old metal shavings and bearing material in the sump and oil filter.
When I assembled it I thought I cleaned everything, but obviously not. I am suspecting the oil cooler. How can I make sure it's totally clean? Is there any other component that holds a lot of debris? Like turbo or cooling lines?
