For large fueling changes you'll prolly wanna do some work in all of the below maps:
F29 - Base Pulse VE vs RPM vs MAP
F30 - Base Pulse VS vs RPM
F31M - Base Pulse Inverse Air Temp vs ADMAT
F77 - Base Boost Multiplier vs MAP
Use F29 & F30 for fueling changes that affect all boost ranges. You may already know this, but F29 & F30 are added together to get a combined VE for open throttle conditions. Basically, a value from F30 is given based on RPM alone, then it's added to the corresponding RPM vs MAP cell data from F29. Obviously, F29 ends at 100 MAP and 4000 RPM, so any condition outside of this range (4000+ RPM and/or 100+ MAP) assumes the lower right-hand cell data (100 MAP & 4000 RPM).
Okay, with that outta the way, you may wish to do some tuning in F77. This is the only fuel multiplier we have based solely on boost. Wanna tune for high boost conditions w/o hacking up the VE tables?.....use F77. This table is pretty self-explanatory, just remember that it is a direct multiplier, so the higher the number, the higher the fuel delivery.
Now, F31M.....the most overlooked fueling table, and probably the one you'll wanna look at the most. F31M uses a BPW scalar based solely on MAT temp.....so you could have a reduction in fuel delivery based on a drop in MAT temps. Figure out the average MAT temp with and w/o alky and design the map around that data. Just make sure to give some fuel lead-in and lead-out, so that you don't have abrupt fueling spikes (could lead to rich/lean jumps that promote detonation, etc....). Also, keep in mind that this table uses Kelvin for the temp range, so be sure to convert the temp data before making changes.
I hope this sheds some light on the fueling structure of our trucks (there's A LOT more to it than this). You might wanna look up some of the big alky users out there to see their results, changes, etc....
Odiwik.........didn't throw it away, just a really tough question to nail down in a quick reply. Gimme a little more time and I'll have some info for you.
Hood
