coupecustom
I started a WTB thread earlier today because I was looking to swap out my under drive pulley for a factory crank pulley in hopes of making my AC compressor run at its normal operating RPM at idle...thus cooling the Ty a little more. Well I basically did a test with a vent thermometer and ran the truck at 2200 RPM for 5 minutes. Temp dropped about 4 degrees. My thought here is that it would be about the same as if I had a factory crank pulley.
The vent thermometer showed that at idle, with the AC on full blast, I was getting about 68-69 degrees. Running the RPM to 2200 about 64-65. Still not enough to be comfortable, but I'm still thinking of trading my under drive pull kit since it is indeed better.
Point is, how can I get the ac system colder? I've read that with R134a in these trucks I should run a different low pressure switch...well that's really only if the compressor is cycling....mine isn't. I don't have any covering on the accumulator...not sure if that would help much. Just looking for ideas since its hot as hell here in FL. Thanks
