how to get base boost
gmcturbo
I'm trying to track down some boost loss. Do i just unplug the wastgate solenoid or do i run a vaccume hose from the wastgate actuator to the port on the turbo. i should get 8 psi right? My problem is i lose boost at about 7psi, it goes down to around 1 or 2 then comes back up on the highway around 35% throttle. datamaster shows no knock, constant tps %, and target psi is constant also when this happens. i have replaced the vaccume hoses on the turbo. truck is stock- i have a datamaster file if anyone wants to see.
thanks-
mike
