Re: How to run cooler?
im confused. why are you concerned that much about temp in stop n go? the system is naturally going to heat soak as you sit with minimal airflow. even if you had alky or an A2A, its not going to help lower temps when your slowly rolling in traffic. the only advantage with A2A is when you finally get moving, it'll take less time for temps to drop. Alky is sprayed during boost...not for normal driving conditions.
whats your temps when you actually are driving or racing? just like Tim, back when I had water/air i was seeing temps in the 130-140 range during the hot months in stop n go and around 110-117 while driving during the day. Florida summer = hot and humid
seems to me if your temps are good when you are cruising or racing, then i wouldnt add anymore crap. adding fans will gain you a few degrees cooler if you want them while sitting in traffic just to have air movement, but i just dont see the value since your not going to be in the gas during traffic.
if you want to add fans to something, add a cooler for the trans and cool that instead.
