How to set base timing!!!!!
autoaddictions
Setting base timing on new motor??? I know this has been covered before but i didnt find a how too . Whats the procedure on this ???? Any help of a link. im running a big stuff 3 ecu so im not sure if the timing setting is the same thing.
MIGHTYMOUSE
Turbo F body guy
Re: How to set base timing!!!!!
mark the balancer at tdc, command a static advance figure (check box in operating config)
look at the crank and see what the actual advance is with timing light.
move the crank offset value ahead or backward until actual timing = commanded timing
thats it.
