How to set fuel pressure
psmvchaser
I just (re)set my fuel pressure.
To properly set it, you take the vacuum hose off the afpr, and then set base fuel pressure. Correct?
I set it at 45, then put the vacuum line on and it dropped to about 36-37. Does that sound right?
kwick6
yep, thats it. Its also good to verify that fuel goes up with boost 1:1 ratio.
come by tomorrow if you want, I'll be around. I'd like to try a known good stock chip in your truck, to see whats causing the closed loop issue. I also have a spare ecm we could try. Bring your 2 bar map with you if you decide to come by.
