thanks everybody for their help, So as i read this:
T1 15psi Street timing (~14 deg at WOT), 18psi, WOT fueling setting 1 LEANEST
T1 16psi Street timing (~14 deg at WOT), 18psi, WOT fueling setting 2
T1 17psi Street timing (~14 deg at WOT), 18psi, WOT fueling setting 3
T1 18psi Street timing (~14 deg at WOT), 18psi, WOT fueling setting 4
T1 20psi Street timing (~14 deg at WOT), 18psi, WOT fueling setting 5
T1 22psi Street timing (~14 deg at WOT), 18psi, WOT fueling setting 6
T2 17psi Street timing (~14 deg at WOT), 18psi, WOT fueling setting 7 RICHEST
T2 18psi Race timing (~17 deg at WOT), 21psi, WOT fueling setting 1 LEANEST
T2 20psi Race timing (~17 deg at WOT), 21psi, WOT fueling setting 2
T2 22psi Race timing (~17 deg at WOT), 21psi, WOT fueling setting 3
T3 18psi Race timing (~17 deg at WOT), 21psi, WOT fueling setting 4
T3 20psi Race timing (~17 deg at WOT), 21psi, WOT fueling setting 5
T3 22psi Race timing (~17 deg at WOT), 21psi, WOT fueling setting 6
T3 24psi Race timing (~17 deg at WOT), 21psi, WOT fueling setting 7 RICHEST
if i'am way to rich at WOT in T1-15, there is no way i change that with my ultimate, i only can set the feulpressure lower but than i have to set it around 30PSI..
Thanks once again
