I just got around to upgrading my fuel pump and figured I'd have a little room to play before doing injectors but saw that I am hitting 99.7% DC at 4600 rpm on 18 psi, AFR at 11.9:1. Fuel pressure is at 42.
I was just curious what kind of power this equates to at the crank, can one just multiply fuel flow by AFR to get a pretty close number or is there any reason this would be way off?
Ex: Injectors flow 30.9 lb/hr at 42 psi (based on 32lb at 45psi)
(30.9 lb/hr) x (6 injectors) / (60 min/hr) x (11.9 AFR) = about 36.77 lb/min of air
So roughly 340-360 hp?
