spooldup
Super Member
Nick ny were workinh on the ty today to try and isolate the idlie hunting problem. Here is what i have replaced so far.
I have replaced the cap, rotor, module, pickup coil, plugs, dequick afpr, vac lines (tested), atr wires, walbro fuel pump, fuel filter, iac, gm tec, snap on motor vac, egr blocked, pte 50's, cleaned and added grounds, checked true tdc and set timing to 0, battery, alternator, o2 sensor and i think that's it. The damn idle hunts all over the place. I will try the computer next i guess?
Well we plugged nicks computer in from his ty and this is what happend. My iac position with my computer (reman bluestreak) was set to 32 at idle via tb adjustment screw. When we plugged nicks in, the position was at 6-7. What's the deal with that? So to try and fix this i began to adjust the screw again to 32 with nick's computer. I was screwing it counterclockwise to raise the count. It only went as high as 20 when the screw was all the way unscrewed and could just fall out. Any clue? The idle hunt was still there with his computer but we never could adjust the iac.
