#2875
built, not bought
i have been working on this problem for a while now and thought i might see what you guys have to offer. basically my truck idles shitty after warmup. here is what i know:
1 leakdown check was good on all 6
2 boost leak check good, am leaking a little around the throttle shaft but not enough to cause a problem plus the tb is new, vacuum is about 17.5-18 at idle
3 a/f mixture is perfect datalogged on the dyno (ultimate chipped (vortec, 412, 50#ers))
4 valve timing is perfect, cam is on standard tooth, not adv or ret.
5 spark timing is perfect
6 i set the idle screw using a procedure i found here. unplug iac, connect pins, blah blah you guys know the drill
7 motor is fresh, i have all new sensors (no egr) multiple spark box, hot coil, ngks gapped to about 32
is there anything i am missing? the truck screams with any throttle but i am starting to grow tired of wondering if it's going to shut off at the stop lights... it never does but it teases me.
