hvac ac blower volume question?
I dont know if this is the correct subforum. Well when ac is on theres air coming out the bottom.heater vents on the dash and thru the normal forward facing vents but not as much as my buddys truck which you feel the blower real good and most of the time have to turn it down,now my truck has to be on highest speed in order to feel it out the vents. It doesnt blow out the top defrost. You hear the blower working on max you just donyt feel it all coming out since its exiting be lower dash heat vents.
Any help please ac is in florida is a must
jeepruby04
Re: hvac ac blower volume question?
This was the issue with an SGT I helped a friend fix that had the same symptoms
thanks for the help guys are those pics posted from inside the ac box or from the outside of it? im guessing the white plastic looking piece is to be the culprit of my lack of volume>
jeepruby04
Pics are from the inside of the duct near the console. The vacuum canister is near the gas pedal (removed in pics).
