Hydra boost brake line question
Big Mike
While checking out Mark's Ty (Quickstop UK) I had noticed that he had his brake lines reversed from what looks like to be the stock set up on our trucks when not running a hydra boost set up. On a stock booster set up the front reservoir (towards the front of the truck) on the master cylinder looks like it goes to the rear wheel cylinders and the rear reservoir (closest to the brake booster) looks like it goes to the front brake calipers. Well on Mark's ty he has a hydra boost set up and has his lines reversed from stock with the front going to front calipers and the rear going to the rear wheel cylinders. What is the right way to run the lines when you change out to a hydra boost set up? And could this cause problems if it were not run right? His master cylinder has two separate reservoirs to hold brake fluid, the front one being smaller than the rear one whereas our stock set up has one reservoir split for both. Is the valving within the master cylinder specific to front and rear brakes and is the per portioning block specific also as to where you hook up your front and rear brakes?
mattw
Re: Hydra boost brake line question
The setup he used is stock on an Astro van. It think the reservoirs are set up that way to clear the hood. As far as the lines being reversed like that I have no idea if they are supposed to be that way. When I did mine I reused the stock reservoir and master cylinder so I left my lines they way they were.
cloneman315
Mine was like that for a while,I am in the process of going the way gm says.rear to front front to rear
Quickstop [UK]
Combating adversyty.
MIke,
Thanks for asking the question :)
I don't think this is a hydro boost issue as the lines are hard from the master cylinder as far as the proportioning valve.
I did an ABS delete so the lines from the proportioning valve go straight to the brakes. I am pretty sure they can only go on one way. Hood made the kit, maybe he can chime in? I'll look for hit kit.
I maintain that my booster is not working as it takes considerable pressure for me to try and stop the truck and hydroboost shouldn't do that.
