Windedv6
Ty n 10s
I did my setup the hard way. I mounted the hydraboost upside down so the lines were hidden a little. This caused a custom type hose setup as well as the need of a machined adapter for the return low pressure line.
The easier way is to keep the unit upright and just buy the hoses from NAPA. Ask for a 1 ton truck with a small block. I heard that even the hoses from a 1973 1 ton truck fits great. I actually searched through the local Napa warehouse and found houses that had curved metal ends that seemed to fit ( becaused I wanted them hidden) and then cut them to length and used connectors (crimped style to pressure fitting) to make everything work. It was painful but I wanted a certain route for the lines. Again, the easist way is to mount the unit normally and buy the right hoses.
The system that I bought was from:
ABS Power Brake
233 N Lemon St.
Orange, CA 92866
714-771-6549
www.abspowerbrake.com
I bought the complete package (no hoses) and went with their recommendation for the HD master cylinder (used on the vettes). You can just get the hrdraboost unit and use your own master cylinder. You may need to do some adapting for the shaft and the bore size will have to match (you can give them your bore size when ordering) My bore size (using thier HD master cylinder) will not fit the stock master cylinder. The line pressure can push 1,800+ pounds vs 800-1,200 for our stock pressure. The company didn't recommend the lighter duty stock alunimum style, but ppl have done it that way.
Other than the hoses the system I bought was a bolt on with no changes needed.
There is an article in the the September 2003 "Chevy High Performance" mag , page 126, that has an article on this compamy and install instructions.
When you order you will have to decide if you are going to use disc/disc or disc/drum as the combination valves (proportion valve)are different. You will have no problem keeping drums on the rear with this setup.
Hope this helps anyone thinking of doing this setup.
John
ABS Power Brake
233 N Lemon St.
Orange, CA 92866
714-771-6549
John
