I.A.C. bad?
It's just a six
Super Member
Hey guys ,
just thinking of posibilitys of why my Sy is running rich @ idle & even when I bring the rpm up to 2000-3000 ,the A/F ratio stays @ 10.1 .
I am wondering if the IAC goes bad, is there a code for a bad I.A.C. & will I get a C.E.L.?
Also, if the I.A.C. is bad, would I get a rich condition?
When the engine is in say a limp mode,, what A/F ratio have you guys seen?
The engine will start, when cold, never run @ the higher rpm warm-up mode, then drop rpm & lean out the A/F ratio to the normal 13.9-14.6 or so.
The engine will start fine & stay @ idle RPM & not change RPMs @ all from a cold start, A/F ratio stays @ 10.1 .
I just changed the narrow band o2 sensor to see if that would help, but it did not.
I am working on hooking up T.P.5 RT, but in the meantime, any ideas guys?
Thanks
Rick
It's just a six
Super Member
Re: I.A.C. bad?
Ok guys,
, took the Sy out for a drive to my friends house w/a portable wideband reader to confirm the engine is running really rich.
We confirmed it as both o2 readers were reading the same A/F ratios.
Go for a w.o.t .blast & the A/F mixture is fine running 24 psi & a A/F ratio of 11.4-11,8 depending how much I turn up the alky control.
So, w/that being done, we were thinking a injector might be stuck partially open causing it to run rich @ idle & @ cruise.
Started it up this morning & the cold start cylcle seems to be working, it starts & runs @ 10.7 A/F ratio, warms, up then the A/F ratio will stay @ 10.1.
I unlugged the 3 drivers side fuel injectors (one at a time) & noticed the front 2 unplugged injecters (1 @ a time) the A/F ratio stayed close to the same, but & when I unplugged the last one the A/F ratio leaned out to 12.4
Could the injector that I unplugged causing it to run a bit leaner be the stuck injector? Maybe there are more.
I bought the injectors used & had them cleaned & flow checked & all were good.
I probably put 200 miles on them since installed.
Most of the time the Sy sits but started on occations. I bought a bottle of injector cleaner to see if that might help,but I doubt it.
Any thoughts guys?
Thanks
Rick
Beavis
Still plays with trucks
Re: I.A.C. bad?
I had a bad ecm do something like this. Real rich at idle, criuse mode, but seemed to be better at hard throttle. Swapped it out all has been good since.
