I/C's..... what's best?
James Thomas
"NO CLASS"
Ok I may be about to open a can of worms but here goes. I need a larger upper I/C & lower CCH but have not had any luck finding reasonably priced used ones, I have had a request on WTB for a while now. So...... If I buy a new lower CCH, which is the best to get, pros / cons on mounting size, performance etc? Griffen, DeQuick or ?? I know Tony ain't got the best rep. but he is trying to clean up his act, so I know the past problems if I do decide to by from him. But I do need some advice on what is the better option for a high performance lower CCH.
Same thing with the upper I/C. I need one but not for $800.00 plus brand new or crazy used. Any one have alternate options I could look at? Any one have a used upper or lower they want to let go? Oh, I know someone is going to mention A2A but I don't really want to go that route.
Many thanks in advance!
________________
James Thomas
cloneman315
Re: I/C's..... what's best?
i used the stocker with my homemade ice chest with a bilge pump from a boat and it worked very well made the intake charge real cold but didnt last 2 long was good for a few runs,now i have the mccoy fmic
VermontTy
Support Our Troops
I'm just going to toss it out there becuase I know someone will if I don't.....
The stock IC and heat exchanger has been proven to be quite efficient in the past. What are the plans that might require such an upgrade?
HotRudyRod
I had the same question some time ago and like VermontTY told you the stockers are quite efficient. After reading, researching and comparing options i settled for a bigger IC pump, alki and a NOS IC spray bar system for the track when the truck doesnt have enough road to cool off the lower IC.
James Thomas
"NO CLASS"
Thanks for the ideas guys. The actual efficiency of the upper for cooling is not the issue, it's the air flow & I/C inlet size. I don't want to run a ice chest or spray bar at all and would like to avoid alky if it can be done. Not to say that I won't use alky, would just like to see how far I can go with a properly set up (read sized) wet I/C system and the special heat exchange fluid I am working on. As to the build, I will let every one in on it when the time (& numbers) are right. I don't want to sound like a blow hard and look like an idiot cause I make mistakes all the time :rotf: and I may be a while getting this the way I want it! Just looking for a little help with this stuff cause most of the companies that use to make them are either gone completly or no longer support SyTy's!
Anybody?
_______________
James Thomas
sy#2716
SyTy 4 Life
Are you just trying to get the Intake temps down?
If so just spray meth. or alky.
I used it in a mid 90* day and i was sparying and the intake temp stayed around mind to low 70*.
qbnkiller
Conflaguration Specialist
did you see the dyno run of the engine Campbell's did for Mark Campbell? They are still using the stock upper IC and stock DP and everything, and put down 750FT/LBS TQ and over 600HP. coat the turbo, DP, and headers/xover pipe, and that will go a long ways. If you need a real nice looking lower CCHE, LMK...mine is out, along with the mounting brackets.
James Thomas
"NO CLASS"
Thanks Alex, I'll let you know.
_____________________
James Thomas
HotRudyRod
Damn, those are some big numbers for the stock down pipe. I just bought the whole insulation kit for the exhaust and turbo, glad i did that before the DP. Thanks.
Flyin Ryan
hated cuz he drives fords
How about using some dry ice on the upper intake... that seems to cool pretty good. As far as flow i've seen a few members modify the ID of the opening to the upper IC which im sure helped with flow.
Loeryder
It is pretty std to bell mouth the opening of the IC to get as much direct flow as possible.
I have seen a couple upper IC modification to run a larger inlet but thats gotta be money to cut and weld a new end tank on the stocker.
I wanted to go all out for W/A but decided there jsut aren;t enough options for the money.
ATR upper IC is about your only option there and its overpriced and fits like crap.
DeQuick's lower CCHE is larger capacity and direct replacement, but I doubt Tony is gonna make ya one IF you can even get ahold of him.
Supplemental options for the stock setup are:
CCHE scoop - to direct more air up under the bumper
Larger IC pump
Dual IC pumps
Aux IC cooler - ie ATR/Hayden cooler in series with stock lower
SPAL CCHE fans - run dual fans pulling air through the lower cche
Add all these mods up and you could of had a nice A/A setup, less weight, less tubing, more bling!
A/A gets my vote.
When the day comes I will be selling my bell mouthed upper IC (drilled for alky injection), Dequick lower CCHE with dual SPAL fans, Johnson pump and 10' of 3/4 heater hose...
James Thomas
"NO CLASS"
Larger IC pump
Dual IC pumps
A/A gets my vote.
Well if you decide to let go of the CCH, Pump and Fans any time soon, let me know cause I'll take it as a package. Tony has them in stock but I'm just a cheap bastard. On the Upper, I am just about to decide to fab my own cause I can get a lot cooler intake charge than any air to air, A LOT COOLER. Let me know if you want to let the CCH / package go.
______________________
James Thomas
It's just a six
Super Member
I can't remember for sure... but my friend fabricated a 2.5 inch inlet pipe welded to the intercooler & picked up a lot of CFM... I'm not sure the stock intercooler CFM was about 650??? & w/the 2.5 inch itake pipe welded to the intercooler for the inlet it went to 850CFM ???? I will ask him later.
Anyways with that mod it made a huge difference in air flow.
James Thomas
"NO CLASS"
It's just a six said:
I can't remember for sure... but my friend fabricated a 2.5 inch inlet pipe welded to the intercooler & picked up a lot of CFM... I'm not sure the stock intercooler CFM was about 650??? & w/the 2.5 inch itake pipe welded to the intercooler for the inlet it went to 1000 CFM ???? I will ask him later.
Please let me know because I have yet to find any one that has modded the stock upper (or that is willing to share info anyway?) to find out what the real bottleneck is and 1000 cfm is huge a flow, imay be wron but I doubt that a stock core can flow that. I hate to take a perfectly good upper and start hacking it just find out that the mods aren't worth the gain. I think that the inlet may only be part of the problem as the actual core or design of the inlet side box may be a problem. The actual inlet dia. has got to be a problem with an aftermarket turbo outlet of 2.5 or larger but I don't know how much? Any one have some info to share with us?
__________________
James Thomas
It's just a six
Super Member
The inlet is the bottleneck & it made the biggest gain in CFM, he did not do anything else to it.
I thought someone has run a stock intercooler & ran low 10's ...or high nines?
Try Me
I think Denny Raab has been like 10.30s area with the stock liquid-to-air setup. I dont know what if any mods were done to it but im pretty sure its still the stock pieces. Please correct me if im wrong here...
James Thomas
"NO CLASS"
Ok this is getting better, anyone have any solid info.? Flow numbers and actual mods would be nice. I think I can get intake temps in 40-50 degree area or better on the cooling side of things just gotta get real world C.F.M. flow numbers now. Any body got sure numbers on the stock upper I/C vs. K/B, ATR, Conelly or others?
___________________
James Thomas
bezerk
A2A makes it alot more easier to work on the truck, and looks cleaner, that's why i did it
James Thomas
"NO CLASS"
Agreed :tup: ! But not as efficent at cooling, espically at low speeds or "cruzin" red light to red light then punching it a little. Friend of mine had a Shelby Charger with A2A and the damn thing would knock from 0-50 mph when running stop & go. After 50 it had enough air moving through it that it stopped retarding and ran like a raped ape after that (for a four banger back in the day anyway). This is going to be a "red light special" I gotta have it from the get go!
James Thomas
