I fixed my low boost problem...by doing nothing?
Throws
OK... I've been trying to wrap my head around an issue where I was only seeing 8-9PSI of boost (via ALDL):
http://www.syty.net/forums/showthread.php?t=85569
http://www.syty.net/forums/showthread.php?t=85677
Then, I thought I'd finally "found" it by hooking up a gauge:
http://www.syty.net/forums/showthread.php?t=86108
But... alas... it was not to be. Old Red wasn't going to give up without a fight. A new (more accurate) gauge, still showed only 9ish. So I got bummed out and decided to at least fix the handling. That being done (mostly!), I turned my attention back to the boost issue.
Through troubleshooting, I tried at varying points:
new vacuum hoses - didn't help but took care of the old plastic tubing.
new boost control (?) relay - nothing. I do have have a nice new relay tho.
adjusting the WG rod - nothing, but now within specs.
new WG actuator - nothing, but eliminated a possible problem.
I did the "bike tube" test and found that I do have a leak in the throttle body... it's a point of concern, but (according to DaveP) won't cause a 5psi loss in boost. I was starting to guess it was a bad cat after reading one of DaveP's other posts. So I took off the WG vaccuum hose....
HO-LY CRAP!
There they were on the gauge... 5psi of missing boost. Found. I could have easily spun waaaaay past 15psi, so I was pretty sure the cat was good. Again, turning back to a DaveP post, I pulled the solenoid hose. I could blow through the solenoid when the hose was off... OK... jumpered the ALDL pins, I could blow (but it sounded like it was coming out of the orange elbow?), then I unhooked it, back to coming out of the foam. I could hear it clicking and feel the change when I was blowing.
OK... so that's not bad. I decided to do a "return to baseline", and hooked everything back up. I took it around the block and...
IT'S STILL THERE! (but not going past 15!)
So...success? I'm not sure what, if anything I did. Did the wastegate puck get stuck and running it without the vacuum freed it up? Did blowing throught the hose unstick something?
I'm glad it works.... but I'd kinda like to know why.
-P
Throws
Re: I fixed my low boost problem...by doing nothing?
Addendum:
What is the correct amount of WG rod overlap? I've seen 1/2 and I've seen 7/8.
-P
Chest Rockwell
Glad to see you've found the missing boost, and I understand the confusion that comes with not actually finding the problem. Getting that truck closer and closer to where you want it, good for you Paul.
wildphil
I Love My Ty's
Addendum:
-P
I read on old post or article. A long time ago. That it was origionally 1/2 then changed to the 7/8.
RealFastV6
@jb_and_his_coffee
Solenoid stuck? I have no idea if that's really possible with these trucks but sounds like it was the case.
Throws
New solenoid. Factory GM. I bench tested the old one and it worked too.
-P
BoostedSUV
Don't ask questions.. Just enjoy it while you can! Lol
Throws
LOL... True. First time since I've had the truck that it actually had all the powre it was supposed to. Runs a million times better now.
I guess I have to pull the fender liner now... I set it at 1/2.
-P
BoostedSUV
-P
Mine is set at 1/2 and I have solid steady boost. I don't think going from 1/2 to 7/8 is going to be all that critical. You may pick up a little more boost but as long as your boost is stable and solid I wouldn't sweat it.
Theorectically you will not pick any more peak boost as long as the boost control system is stable feedback system. The ECM controls boost above base boost setting and is feedback control system.
