I hate roof racks!
jbone
The other day I was installing a new battery tray in the rear of the Ty. After lifting the carpet to drill some holes I noticed it was slightly damp underneath :roll: . My first thought was that it was the rear window seal, as I noticed water would pour out of the wiper thingy when I lifted the hatch. So I pulled up the rest of the carpet in the rear and realized that it was soaked all the way up to the back seat. And I mean SOAKED. :rant: I cut the carpet at the back seat. Threw it on the ground and water was pouring out of it. I almost needed a wet vac to suck up all of the water. I was hoping that it only got to the back seat and not further, but it traveled past the rear seat on the driver side. So I guess I know what im doing next......Replace carpet, replace rear window seal, and remove and seal the roof rack. I highly suggest to anyone w/ a rack to check for leaks. Oh and I also now have to remove the surface rust that has started b/c of it. :tup:
jjorgensen52
NHSTE - I'm the only one!
Re: I hate roof racks!
You should check your rocker panels too... they have a nasty habit of filling up the rocker boxes when they leak. I was fortunate to avoid that one.
You going to weld up the rack?
jbone
nope Im going to be doing pretty much what you did. I just have to figure out where to get those caps and o-rings and whatever. I'll be ripping the entire interior out and going through the whole truck inside and out to see where else all this water went :roll:
fronzo
FTT Customs
My blazer does the same thing, my carpet isnt we, and when pressure washing at the rear window, I can see water leak, so hopefully its just the rear window seal. I did remove my rack as well, its sealed up with strip cauk right now, untill I weld it up. I'm doing rockers, replacing front fenders, hood and doors as well with GM panels, since I see someone was already there "fixing" it....
jbone
well I pulled the whole interior out of the truck. And to my surprise it wasnt all that bad. The puddles on the floorboards werent as big as expected and there was very minimal surface rust which is now fixed!! next the roof rack comes out this weekend and the new carpet goes in. I was also surprised to see no leaks from the roof rack....nevertheless out it goes. Anything else I should do while im in there?? (Aside from insullation)
WannabaTY
Once I decide to stop driving mine for a few weeks, I am going to have the roof racks removed and the holes welded up. I already have a new rear window without the wiper holes. Keeping the defrost though.
