I hear pinging!
SEL777
One of 101
I seem to have a intermittent problem with a pinging sound every now and then. This is not while driving at WOT just normal daily driving. It seems only to happen just before the 1-2 shift then it goes away but, I really need to be sure about WHEN it is happening. Rest assured that I ALWAYS have run Shell V-Power 93 octane since I purchased it back in NOV '04. I did a tune up with the good stuff in April but, we did not time it. I also have not had it run on a DM. It seems to only be noticable only while the A/C is on. I do not have dash lights or anything noticable in performance loss when I do open it up every now and then. Any help would be GREAT!
TYRODD
My ass. Look at it.
Re: I hear pinging!
Just a thought...
What is your voltage like with your a/c on? There are ways to check this without DM...but you should definiltely get DM :) . Definiltely check your timing.
SEL777
One of 101
Re: I hear pinging!
I'll look again tomorrow. I will put it on while running and see where my volts are. Should I use somthing other than my gauge? I recently replaced the alternator. Not this would have anything to do with this.
TYRODD
My ass. Look at it.
Re: I hear pinging!
Actually it may :)
Poor voltage can definitely hurt you. That directly effects the ignition components which effects knock dramatically. This problem combined with poor ign. timing will definitely contribute to knock.
Without DM, a multimeter/voltmeter is the only other way for checking voltage. Dont read the stock guage, It wont tell you a whole lot :) .
SY2932
Administrator
Re: I hear pinging!
If you aren't already aware, this wire has to be disconnected when you set the timing:
"The ESC Electronic Spark Timing "tan wire with a black stripe" that everyone can't find when attempting to set their timing (s-series). Wire is under the carpet on the passenger side below the heater box. It is disconnected to set the timing, then reconnected."
Definately check it and report back what you find. However, the fact that the pinging is limited to the 1st to 2nd shift is odd.
TYRODD
My ass. Look at it.
Re: I hear pinging!
Werd,
Are you sure it is engine knock, and not something loose/banging around. That 1-2 is strong enough to move a few things around, even at part throttle. Could be a catalytic convertor or exhaust bracket banging up on something :?
SY2932
Administrator
Re: I hear pinging!
TYRODD said:
Werd,
Ditto. During one of my out of state "4L60 pull escapades" to help out another owner, his heat shield over the downpipe was loose. We pop riveted it in place to shut it up. A loose heat shield can mimic the "marbles being rattled around inside of a coffee can" sound that signals detonation. This seems to be more likely the case since you don't experience it any other time especially when you get on it. If you have detonation without getting into boost, you will surely have it (not for long) when you are in boost.
