I keep blowing valve seals - help!
Turbotrux
Today the wife calls me from the cell and says "this big puff of smoke just came out of the Ty & the CHECK GUAGES light came on then went off"
Well, that's exactly what happened to me 1.5 years ago - valve seals - specifically the one closest to the EGR port...AND it also happened about 1.5~2 years before that - SAME ONE!
Unfortunately I don't have enough time to spend with the truck to keep it tuned and running 100%......but to me this shouldn't happen. Has this happened to anyone else?
Just 2 days ago I had Diacom hooked up to start finding my knock/no boost situation and discovered the integrator hovers at 165ish @ idle and as much as 210ish if you hold it at 2k rpm - LEAN!!! I've checked for vac leaks and everything seems fine.....I'm wondering if I might have a sticking fuel injector or two. The only reason I say that is last time I had the top end apart I stripped and re-powdercoated the fuel rail and in the back of my head I almost think that there was some goo that might not have got flushed all the way out.......Ign system is in top shape (new plugs, cap, rotor, wires, pickup coil, coil, timing @0) so I'm leaning towards fueling.....not sure on FP yet - guage is at a friends house.
Any thoughts, suggestions, ideas?
Thanks in advance
Turbotrux
Well, it's stranger ...... the truck was 3 qts low on oil ..... added last night when it happened ..... full this morning.....started and NO puff of smoke usually associated w/ bad valve seals...... I think I'm just going to start building my other engine and save myself the headache of chasing the same problem with one hour here and one hour there.....
Turbotrux
Yup....I should....I even bought the guages 6 months ago and they still sit in box untouched......
Yesterday I found an ignition problem, too....thought everything was in good shape, but now it's not......I need to take the thing off the road and spend some time with it.......it's hard, I've got a wife that hates the mofo and I swear she is trying to kill it!
later
