SY2932
Administrator
I had Jim Longwidth's stainless steel "Blade of Death" intercooler scoop for over five years on my CCHE (charge cooler heat exchanger). Running a rigid scoop requires a higher level of alertness when you are driving due to the possibility of hitting something with it and ripping the CCHE off in the process. I have had a few close calls over the years mostly large roadkill that I was able to avoid. However, tonight my luck ran out. I was on my way into town rounded a turn at 50ish MPH and see this laying across the road just as you see it:
Before I can say the "F" word and even attempt to get on the brakes, I hear a dull THUD followed by scraping sounds as it passed under the truck. I pulled off the road ASAP and expected to be missing my CCHE and possibly a few pieces of cladding at the very least :roll:. To my surprise, the CCHE was still intact but the scoop was trashed:
There didn't seem to be any damage to the cladding other than some scrapes on the bottom of the roll pan. I could see where the tire hit my freshly painted rear driveshaft too... Getting the scoop off was "fun" since the bottom support got bent back so far that the studs that hold it on were touching the sway bar. I was planning on making a different scoop over the winter out of aluminum. I can get an early start since I prolly won't be reusing my old one:
I got off easy, things could have been MUCH worse. The recap has spots on it where there is NO tread so, I was way past due to be replaced. It's better to just the tire self destruct on the road and let other motorists deal with it rather than hurt the bottom line
