I need a chip FAST!
GREperformance
Hello everyone,
I own a shop up here in Lancaster, Ca. and took on a project to build a customers 92' typhoon. Let me tell you this thing has been a nightmare; but anyhow let me cut to the chase. We have the truck finished now. We went through the motor, rebuilt it with forged components and ARP hardware, SCE Titan Headgaskets, a Bullseye Power 60-1 Turbo, 3" stainles mandrel bent exhaust, HUGE front mount intercooler, it has a .510 lift extreme energy comp cams, new rearend, a fully built Mike's Trans 700R4 with a 10" stall converter. Anyhow the list goes on and on. Now to the problem; we purchased a Perfect Power (PP) piggy-back system for fuel control because we were led to believe it was the best thing out there since chips are hard to come by it seems now. We decided to leave the stock fuel injectors and use the Injector drivers the PP has to drive two 650cc low impedence injectors for supplimental fuel under boost. This seemed like the ultimate solution, drives like stock around town and plenty of fuel capability up top for driving hard. Well we have been fighting this thing for a month now and cannot get this thing to perform as advertised as well as the interface feels like it was programmed on an apple IIE in 1986! So, I have tried to contact SyTychips.com with no luck, and I cannot seem to find anyone with a 3bar 50# injector solution. Can anyone lead us in the right direction? Thanks for the help in advance!
jwaller
Evil Genius/SyTy Guru
Re: I need a chip FAST!
send me the $ and I'll send you a chip. there are 6 or ppl here that can help you including mike who you got the trans from.
Sounds to me like you have a computer mess.
I am sure one of the several guys here could send you a chip that will run. Tuned to match what you have done I doubt. Stock injectors are not going to handle the mods you have listed.
Get rid of those additional Injectors, you will have issue getting fuel to the first & last cylinders because of distribution issues. For 50# chips besides the ulimtate, (Nolan) 10secTy, (Dig Bartholomew ) turbodig, & (Phillip Long) turbo6 all do custom quality 3 bar chips.
GREperformance
Thanks for the replies.
Do these work well enough to get the A/F ratio dialed in or do you have another device to fine tune it? I decided to try the piggy back in the first place because I was worried about how close a mail order chip could be, but I am not very familiar with the Typhoons and I am a big fan of the AEM EMS myself so I am used to full control of the ECU.
By the way, jwaller, you may be mixing up the trans guy I used. Mike's Trans is local to us here in Lancaster, CA. I have seen a few other Mike's transmissions on the internet.
You will need a scan tool and probably have to do a few back in forth to dial in a chip, but you would really need to talk to the tuner. I am sure a WB02 would be helpful.
We do actually have a full control ECM. It doesn't have the nice graphics and features of some of the aftermarket ECM's. For instance we don't have close loop WOT WB02 tuning.
Feature wise that is changing but its still in the testing stages. This isn't going to do you much good if a customer wants there truck back some soon....
GREperformance
I don't know of any PROM tuners local to us, so hopefully JWaller can get it close. We have an AWD dynapack dyno and software to tune just about every system out there, but we have never gotten into custom PROM tuning. We seem to do mostly AEM EMS tunes, MOTEC's, SAFC II's and ECU+ units.
If you can tune the other stuff, the stock ECM won't be hard to learn. www.moates.net sells the hardware you need, several posts on here discuss it also. I have put up fuel tuning notes, etc.
Information is there is you want it. For our application I would say for 95% of the truck an aftermarket ecm will lose features (like tcc lockup, etc). With the new chip being developed it makes that gap even smaller and I would even go as far as saying soon it won't exist at all and be the other way.
