i need a hardpipe
TwistedTy
More boost! N.A.S.T.E
hehehe i knwo ya love the title.......... i am running a innovative 60-1 turbo with the stock I/C setup. now my problem is the crappy radiator style hose is expanding and obviously not allowing me to install a blow off valve. its an odd bend kind of like a s shape. anyone know where i can get a hardpipe?
GM TURBO
Sell Out
Re: i need a hardpipe
The subject line makes me laugh.
Why do you want a blow-off valve?
hard pipe. blow. expand. And we aren't talking about sex...yet.
TwistedTy
lmfao atleast i got a giggle out of it. the rpm bend doesnt accomodate the bend i need. this turbo is clocked in an odd position. the outlet going to the intercooler is actually where the #10 on a clock would be. so its nto centered at all.blow off for obvious reason of extending turbo life {hey every lil bit helps} the rubber is expanding alot under 15psi and im gonna be turning it up to atleast 25
gjp
another post whore
Thats got to be the 10th time you called him gay??......Is there something you are not telling us B.K. or do you just have good gay-dar.LOL
Black Knight
I Glow Therefore I am
Don't get me started on you :ninja:
He keeps bringing it up, so I have a nack for pointing out the obvious :devil:
TwistedTy
if i reclocked it the pipe would be going towards the radiator farther away from the turbo cause the distance of the hose. I think this should be renamed the rainbowpipe thread
mattw
I saw the title of this thread and just automatically assumed that smaug had made the post..
-Matt
Black Knight
A pic would help, because I can't picture this at all. How if you reclocked it towards 12 o' clock would that be closer to the radiator?
Black Knight
And reason number 11, he just figured out how to make a gay smiley :rotf:
live1053rulz said:
I always thought this should have been the symbol for gay. :boink: :boink:
Come on Gary you can't tell me it isn't obvious :rainbow:
J/K Stephen, or is it Sphven :D
DynaGlide
Ton-Eighty
An exhaust shop should be able to get you something in galvenized steel that should work. Then you can weld a mild steel flange, and mount your TiAL bypass valve.
ghettosled
SYTY SUPERSTORE
the problem is the outlet of the aftermarket turbo(s) is higher then the inlet for the IC. Therefore you need to make an extremely tight "S" shaped bend in order to get it to line up. Its bad enough with a T04E/T04B cover, i cant imagine how guys are doing it with S or H trim compressor covers.
