I need help with my ultimate!
Turbo6
10.20@131.8
I have the ultimate V3 50# program and the truck idles between 11.5 and 12/1 AF ratio and turns the plugs black. At WOT on the richest setting I can only get it as rich as 12.2/1 AF. I emailed Brian 2 times the past 10 days but no response. Who can I get to help me on this?
E-Rue
whats your FP set at, and where are you located?
there are a lot of NC guys that can help you out if they know where you live.
e
Turbo6
10.20@131.8
Those AF #'s are with 45 psi base FP and an FJO wideband. I could turn up the base to make richer on top end but then it will be even richer at idle. If anyone local wants to borrow the FJO for their truck bring it up to the house and we will hook it up.
I am near Winston-Salem.
smeagol
Sorry i missed your messages, been busy as usual.
It sounds like there is something wacky going on.
I have run the same programs on my truck and have *never* once fouled the plugs, or even gotten close.
Definitely see that your fuel pressure regulator is working - if not, the fuel pressure won't drop when at idle (vacuum) and 45 base will run like a 50-55psi base, and it won't go up in boost, so it'd be lean there as well.
Has the running condition changed? Is this the first time you've put a wideband on it?
Turbo6
10.20@131.8
The FPR is acting normal. The FP comes down to about 38 at idle and goes up to about 65 at WOT and holds steady. This is the first time a wideband has been on it. I was getting lots of retard and didnt know why but now I do....lean....and really rich at idle.
smeagol
Try reinstalling the chip, make sure there isn't something weird going on there.
Get some datalogs of the crappy running condition, and send it to me.
Turbo6
10.20@131.8
I have e-mailed you 2 datalogs 2 times. I will reinstall it tonight and see what happens. Someone on here has a romulator or something to tune with...maybe I could use one to tune it the way I want?
smeagol
1st thing
you have malfunction codes set.
34 - MAP low signal, and code 42 - EST (timing stuff)
reset the ECM, see if the codes come back, then let's go from there
smeagol
Also, be sure you are in 3 bar mode on Turbolink - it will show on the main dashboard display as 2 bar or 3 bar.
Turbo6
10.20@131.8
Yeah the low map reading came when I started it up with the vacuum hose off the map I just didnt reset it. The timing one tripped when I had the timing wire unplugged to see what the base timing was. I will clear the ecu and reinstall the chip and get back with ya. DO you sell the the hardware or can you tell me where to get what I need to burn chips? I am interested in tuning it by myself since I have the wideband and access to a dyno.
Turbo6
10.20@131.8
Thank you for the quick replies and info! DO you know anything about the Romulator that has been mentioned for tuning?
Turbo6
10.20@131.8
I cleared the codes and reinstalled the chip. Its doing the same thing. It really likes to hang around 11.1-11.5/1 at idle. It is starting to smoke now. THe smoke is blue so I guess the cyls are getting washed down. I have a stock set of injectors. Can I just plug in the stock chip without the ultimate and run the stock injectors and see what it does? I looked at all the spark plugs and they are black with soot but not any oil on them. I can turn the base FP down to 20 and it idles at 14/1 or so but I wont drive around like this it gets too lean.
smeagol
Did any codes reset?
Compare an idling log to a log when it was fine - see if pw is the same.
You can run the stock chip with stock injectors - put 2 bar back in though.
Lot of work, for what might be something simple, but if you are willing to try it... you may learn something.
Turbo6
10.20@131.8
No codes now. It has been rich since I bought it from Les. I didnt know how rich until I got the wideband. I'll try to find some old logs of idle to check the PW. I forgot i need a 2 bar sensor. I'll keep pluging away at it. It may be I have bad injectors........
smeagol
Flip through the chip programs as well, see if it runs better/worse with any programs.
Has it always been fouling plugs?
Have you verified your fuel pressure readings with different gauges?
Turbo6
10.20@131.8
Well it has to idle for a few minutes before I pull them out before they are black so I dont know because the other times I have pulled them out it had not been idling long. The o2 voltage at idle on the DM always showed in the 900-950mv range at idle. I tried all programs and idles the same AF on all. My fuel pressure test gauge shows within 1 psi of my autometer gauge. It smokes the most when I restart it after it is warmed up....like 5 mins after its shut off. Has a big puff of smoke. The smoke appears to be white/blue. I can drive it around the bock and then let it idle and it takes about a minute to start seeing the smoke again. It has new valve guide seals and I blocked off the turbo oil feed line and it still does it (stuck a piece of vacuum hose in the compressor wheel so it would not turn) so its not the turbo causing the smoke.
