I need help with tuning.....
Hey list,
Had a few questions for anyone that knows aliitle more on the long term fuel trim. My BLM has been at 150 at a cruise or light throttle and 128 at idle. From what I understand BLM has two cells, open throttle and closed throttle. What does that mean??? Also I know that BLM is only used at WOT when it is way above 128 because you are running lean so it adds more fuel, right?? I want to know if it is okey adjust my FP higher than 46psi(at now) w/wac disconnected to lower my BLM closer to 128?? I have also had 5-8KR at WOT. I tried adjusting base FP to 50psi with no change. So, I adjusted FP to 55psi and my knock is consistantly down to 2-5KR and BLM ia at 140-143 at cruise and light throttle. I have all basic upgrades and stock chip. Sorry for the long essay but Im stumped and any advice would be appreciated. Thanks Fern Sy#477
TyMeUp
I just ran a fuel pressure and scan check on my Typhoon. At 45psi pressure, I have 119 BLM at idle and 124 BLM at 60 MPH cruise. This is with a stock chip and Lucus green stipe injectors. (I think the Lucus injectors are rated at 36#/hr while the stock Bosch injectors were rated at 34#/hr. - can anyone out there verify this?)
Block Learn Memory (BLM) is the 'learned' fuel delivery correction factor that the ECM uses to modify the injector 'on' time pulse width calculation. For the SyTy ECM, it is updated during two operationg modes; closed throttle (idle) and open throttle (cruise); and only while running in 'closed loop'.
When in closed loop, the O2 sensor 'sees' a rich or lean exhaust and signals the Integrator (INT). The Integrator is the short term fuel correction that will immediately add or subtract fuel injection pulse width time. The BLM watches the INT for its 'trend'. If the INT is running > than 128 (adding fuel), the BLM numbers will move up, also adding fuel, but on a more permanent basis. The program's goal is the get the INT back to 128. If the INT is running < 128 (subtracting fuel), BLM will move down, also subtracting fuel until the INT reads around 128.
Your 150 BLM is way too high and right on the edge for setting a code 44. Things to check:
1) O2 sensor heater, O2 sensor grounds, O2 sensor signal line for poor connections, bad O2 sensor.
2) Lean fuel injectors (dirty), low fuel pressure at cruise (have you changed your fuel filter lately?), contaminated fuel (water condensation after storage).
3) Finally, air leaking into exhaust upstream from the O2 sensor from loose manifold, cracks, etc.
Hope that helps.
smeagol
stock injectors are ~32lb/hr. Lucas makes green stripe injectors that are 32, 36, 42lb/hr... depends on the part number. The 36 & 42 lb/hr are very rich at low pulsewidths (not linear) so i doubt you have either of those, or you'd have really horrible drivability, fouling plugs etc.
Thanks for the explaination,
Ive done complete tupe up including fuel filter,
The 02 was changed last week with same results with a Bosh(spelled wrong) replacement. My fuel milage has inproved, the o2 swithces a hell of a lot faster than the old o2, but, BLM is stiil at 145-150. Since you mentioned it, I think the cross over pipe is leaking because I saw black spots aroung where the x-over pipe joins right at the bottom. Ill plug that and see if it helps. I did a pressurized cleaning of the fuel injectors via the fuel rail, guess I assumed that that would clean out any shit that may have been stuck. But I have to do a fuel injector pressure drop test on each injector. Some good suggestions, Ill try these and see what happens. Thanks again. Fern Sy#477
TyMeUp
That exhaust leak would do it. After fixing it, clear the ECM's memory to reset BLM to 128, then road test. If performance seems normal, the leak was causing a false enrichment. If it seems to run lean initially (hesitates), then check out the other stuff.
Thanks Brian. The only clue I had for these is an old early 1990's ATR catalog supplied in a thin file from the second owner of my Typhoon. On a second look, it shows only two choices for "Lucus Disc Fuel Injectors"; #SY377-00 Injector, stock flow; and #SY377-17 Injector, plus (17%).
Many ATR parts were applied to this Typhoon back in 1994-95. I can recognize an ATR Adjustable Fuel Pressure Regulator and exhaust system. I also have the Pit Bull chip along with an ATR receipt dated 6/22/94. It doesn't show the injectors, but does list the chip as #SY137A - Pit Bull, 33#, Lockup. It makes sense now that ATR would have supplied injectors to match their chip ... so 32-33#/hr would be it.
What can you tell me about the Pit Bull chip? The catalog description says: "improved cold start, rev limiter revised to 6000, speed governor lifted, recurved wot advance, redesigned boost curves, inter-cooler pump enabled at lower temps, and automatic lockup of the converter at roughly 85 mph." The last item is confusing, does that mean the torgue converter never locks up below 85 mph?
