I need some help please
bender
I want to learn to tune my truck. I have been reading and reading and I am still pretty lost. I just got all my stuff for code 59 a few days ago, and have it all hooked up. The only thing I am waiting on is a KB afpr that should come monday. I wanted to start looking around in tunerpro but am waiting to do to much before I get the afpr hooked up.
My problem is, because I dont have the first clue what I am doing, I am afraid to mess the truck up. Today I used a starter bin from the 59 forum, it is this bin
"30# Hi-z 4.3 v6 Syclone stock turbo -SBNovahot! 01/31/2009 Hits: 201
Developed for stock Typhoon. Stock boost levels. "
I started messing with the f28 table trying to get my afr at 14-15:1. Once it was there it started hunting for idle out of gear. It was idling fine at 12:1 when colder but once warm would hunt a little as well. I checked for a vacuum leak and the only one I have is at the tb shaft. My vacuum sits at about 15in HG and I am about 1000ft elevation.
I decided to try the auto tune and went for a very easy drive to log. I was watching afr's though and at idle they would be 14ish but under load it started leaning out a lot, even up to 18:1. I drove back home easy and parked it. tried the auto tune but I dont think the small amount of data I got was enough for it as it did not recommend any changes. This brings me to where I am. I dont think I know enough about what I am doing yet to get started and another big consideration is that the weather has turned, its raining more and getting colder. I am not sure I want to try and tune in the cold and bad weather.
I do want to tune with 59, but I am going to study more and learn more before I do and probably wait until springtime to start.
So here is the point to my really long post. Is it possible to use the ostrich and my g3 adapter to simulate an ultimate chip. Can I either use the bins from powertuneplus.com loaded into one of the chips for my g3 and then select them with the moates g3 selector. Or use just one of the bins loaded into the ostrich. If I use the 58 ads and 58 3bar xdf files from the 59 website will either work. Also is there support in any of the 58 stuff for my plx wideband that is installed. It is also hooked up to emulate narrow band.
WyoSyclone
Re: I need some help please
I could help you out tomorrow with the Code59 stufff.... once you get it up and running, the tuning process for drivability can happen pretty quickly. I can't answer your question with regard to the Ultimate.... I know nothing about that.... Dig would be the go to guy on that one.
bender
I would greatly appreciate it.
