i need some opinions........
sharkbait
machanicaly im pretty much done with my build. i just have two or three things to do. I'm ready to tackle the wiring. just incase anyone isn't familiar with my build, im doing a 2gen rwd s10http://www.syty.net/forums/showthread.php?t=75817. i have a complete uncut syty harness. it includes the fuse box harness and the engine harness. i def will be trying my hand at tuning the truck via code59 etc.
now my question to you guys is......should i
try and swap the whole syty harness into the truck? some of the type of problems i might encounter is the steering column is not the same. plugs might be different.
try and swap in the syty ecm to take care of the motor only. keeping the stock harness in the truck to control the ac, lights, etc.
or do i leave it all in and go with a stand alone aftermarket management system? (this could be pricey)
let me know what you guys think. please tell me why you chose what you chose.
sharkbait
Re: i need some opinions........
TY0331, i was thinking the same thing. i ordered the cd rom. hopping it will shed some light on the motor harness/ecm. other than power and ground, there shouldn't be to many "motor" wires. knock, oil, water, injectors, tps, map,wg.
What year is the 2nd gen? 94's were OBD1 and some 95's were OBD1.5 having on OBD1 ecm wired to an OBD2 ALDL port. Both had the ECM mounted inside the truck.
sharkbait
its a 95. it had a TB (toilet bowl injection). it had a 4L60E, but now has a built 700r4. the fuse box is in the dash on drivers side. facing the door panel. the ecm is pass side under the dash.
V
Interfacing two computers sounds cool, but I think you'll have to be a pioneer. I haven't found anyone taking on this challenge.
I've just recently started to research mods for my '96...good tuning software for the early 2nd gen PCM is slim. Luckily, there are established ways to fix the problem.
Your first option would be to swap to the '98+ PCM/harness. I don't know what it would take to work with a '95, but the '98+ PCM is supported by HPTuners. Scott (UR50SLO) has already been there/done that. It would take some work to retain your SyTy intake and injectors. Scott used a marine intake/injectors to run 9 lbs of boost (I think). I have a complete working PCM/harness for sale, if you're interested.
The path that I will probably take is the LS1 option. Unfortunately, I think you'd have to swap to a '96+ harness to go this route (might be wrong). Anyway, the stock PCM connector is repinned to work with a LS1 PCM and tuning is supported by EFILive. The LS1 PCM is programmed with a late S-10 OS for naturally aspirated builds. Boosted builds get a custom OS. Right now, 2-bar is supported. I haven't found any proof of successful 3-bar yet. From what I've read, coil-on-plug, wideband and 4L80E are all supported.
Edit: If your '95 engine is not California emissions, you probably won't have a reluctor wheel for the crank position sensor.
HTH!
bezerk
i choose wire it in. it isn't that hard to do, and you don't have to use all the wires also.
my thought it these are the only wires you need to use for the sytt ECM
power
Map
O2
ignition
FP
Elec fans with relay.
knocksensor.
temp.
shouldn't be hard to do, and it would be like a stand alone managment, but a bit cheaper :D
BoostedSUV
I agree with wiring the sy/ty engine harness into your 95's harness. Trying to make the fuse panel and dash harness work would be a headache! I'm sure a lot more would have to be changed ie: ignitions switch, wiper switch, headlight switch etc etc...
With the Sy/Ty harness you should have to power the ECM, feed the gauges, power the system via the alt, and convert and adapt in the OBD1 ALDL connector to the Sy/Ty ECM etc. I can't see it being too difficult, just time consuming to extend wires and making sure everything that is needed finds it's home. You will definitely need the wire diagrams for both vehicles in order to identify each wire and get them to the right places. Other than the bulk head connector at the firewall and the plug that feeds the instrument cluster it should be a simple plug and play setup. Everything you need for feeds should be there, they just need to be identified and matted together....
sharkbait
thanks for all of your input. poconojoe, thanks for the 95s10 diagrams.
i think i will go with wireing the sy ecm into the truck. removing the 95 ecm. repining the bulkhead connector into the chassis harness.
the big thing with that option would be firguring the "whats what color/what does it go to" to connect the bulkheads together. i have 2 weeks vacation comming up next week. i have alot of work ahead of me.
leadfoot
i think i will go with wiring the sy ecm into the truck. removing the 95 ecm. repining the bulkhead connector into the chassis harness.
I wired a Ty ECM to work on an '02 truck. It ran and drove BBbbbuuuuuuuut the ty ECM did not provide class 2 serial data which is required to run the later model gauge cluster. Not sure what the '95 PCM requires for the dash to function.
So now the '02 engine harness/PCM will be the engine management.
Try to get your hands on a 95' S10 Helms manual. The wire color coding is relatively consistent from year to year -but not everything.
You may also need a signal from the trans for the newer engine management /PCM ??
Also have a DVOM and circuit test light handy. -and lots of spare fuses :rotf:
sharkbait
i was thinking about that too. 95 uses the 4L60E. but i had a 700r4 built for the build. so the speedo wont work with the elect gauge in the dash. im not sure about the other gauges for the dash either.
sharkbait
i was thinking of removing the dash cluster and putting in aftermarket gauges. everything i read about syty factory gauges say they are crap. so why WORK at keeping them?
