I Need Some Tuning Help!!!
Bill Z
Got a 92 Typhoon. Not the first, second or third owner. Most of the time the truck runs great. However at times (like now) the truck dies after sitting longer than 60seconds at a light. While going down the road, it bucks at any speed after you have been running at that speed for a while.
Sometime when coming to a rapid stop at a stop sign, then trying to accelerate from the sign quickly (California stop) the truck bogs down and falls on its face. If you letup on the gas and let it get composed, it runs through the gears like a scalded ape.
The last time I fixed the problem was after replacing plugs and wires. 9 months ago I went to the NKG Iridium plugs. I checked the gap on these today and they appear to be holding the gap. The copper AC plugs would widen the gap from .034 to .045 in just 3 months. Also, I did find one Mallory wire burnt a little by the down pipe. I moved it out of the way with a tie wrap.
The only tuning tool I have is TurboLink 4. I have some recorded runs but I just can see what causes what.
The scans do show where the idle (in park) falls to 200 RPMs and then the truck recovers. I think that if the truck is in gear at one of these moments, it would die.
I have replaced the IAC and the O2 along with checking the TPS. Nothing seems to help.
While checking my vacuum lines, I noticed that one of the check valves was not working. Blowing or sucking, the air just went through. I did replace it but no improvement in the basic problem.
I can email anyone the files I saved.
Please help.
lSyclonel
check to see if you have IAC counts at least 20-30. somtimes ignition modules go bad. do you have any codes?
TrboSy2051
Sounds like a total tune up is needed............. plugs, cap, wires, fuel filter, air filter, etc.......... I have seen one of these items go bad or clogged and the truck run like crap...................... HTH
Buddy
Bill Z
Before I replaced the IAC the count was 2 to 6 and after it is around 30. I figure that it is working being new and all.
Found out that NKG Iridium plugs are warranted for one year so I will take these back for a new set tomorrow. I will get a cap and rotor while I am there.
The Mallory wires are a different story. They cost nearly $100.00. Just a little too much to be changing every 9 months or so. I figure that I will just ohms them out. If one is bad, I'll try to get Mallory to send me a replacement.
Please answer this question for me. My Typhoon runs great under boost. It just won't idle. Is this normal for Typhoons that are having plug problems?
ed hess
race or get outta the way
bill
go search using my name and the word "STALL"
do everyting i did. if you still cant find the cause after that. then its safe to assume your lower intake is leaking.
you should find 2 threads with about 7 pages each to read. thinkit was from all 2 years ago.
this will teach you everyting you need to know.
have fun and get ready to do a lot of work..... just like i had to do.
ed
ed hess
GM TURBO said:
Ed - you resolved it by building the motor, right?
no!!!
we had done everything but nothing worked.
then when doing the new motor i was going to do anyway.
when i went to remove the lower intake with all bolts out, i lifted it off with 2 fingers! no bonding between block, heads and intake!
all the ign and sensor stuff got reused on new motor and stall problem didnt transfer to new motor.
made sense to me that that must have been the real culprit!
ed
lSyclonel
i dont know how many miles are on there. but some times at work just cleaning the intake and tbody with carb and choke clean does it, and i have seen timing do that too.
Bill Z
I was going to change out the plugs, cap and rotor and report back but O’Reilly’s had to get the 6 NGK UR6IX plugs from the warehouse and they won’t be in until tomorrow. I was going to warrantee them out.
Has anyone else noticed that their plugs get eaten up rather quickly? I use to get the copper AC plugs but every 3 months I had to pull them because the copper was melted or eaten down. I would install them at a .034 gap and 3 months later they would be at .045. Big change! These Iridium plugs seem to mot melt down as quickly. However, today I noticed, the tang part of the plug takes a beating. One side (I guess where the spark hits most of the time) is melted away. This makes it harder to re-gap because there isn’t a smooth place to gauge from.
Is anyone else having these problems? And will this cause this stalling problem?
Bill Z
Still Need Some Tuning Help!!!
Guys,
I seemed to have fixed one of my problems. As I figured, there was more than one. Most of the missing, bucking and running bad symptoms are gone now. I replaced the NGK UR6IX plugs. Got them warranted out. Only owned them for 9 months and they had a 1 year warrantee. I would have figured them to last longer than that being iridium and all. For the most part, the truck runs smooth now.
However, some problems still exists that I need some help with.
1. The truck still Boggs down after a quick stop or in a hard turn. It acts like my old carbureted car did if the floats were not adjusted right.
2. It still lurches or bucks or hick ups every once in a while. About 3 to 5 minutes it will get this surge rather than idling or running smoothly (at any stesdy speed even stopped).
With the old plugs and the truck just running crappy, this surging, bucking or hick upping still happened, it was so noticeable that it killed the engine. Now the engine is able to overcome and keep running but I still don’t like it doing that.
Any suggestions as what to check for ether problem? I have TurboLink 4 to check things but what to check?
Again, please help with your ideas.
ABLITZ
Damn Yankee
Re: Still Need Some Tuning Help!!!
quote]
how much gas was in the tank?
these tanks dont have baffles.
Bill Z
Sometime we do overlook the obvious.
The gas tank, oil pan and trans were all full. Anticipating the problem, I check my gauges and there is no drop in ether fuel pressure or vacuum. I even checked the ground connections between the body and the block and then to the battery just in case something had loosened up and the centrifugal force was pulling the grounds away. Everything was tight.
I was wondering if the speedometer sensor was slow on the send or something was slow on the response.
AZTY
The only thing I had similiar was from the pickup lines in the oil pan were coming loose, but I also noticed I had really low oil pressure. So I guess my question is that you are maintaining good oil pressure the whole time?
Bill Z
So, you are saying that the computer senses oil pressure and starts a shut down if the pressure drops and aborts the shut down when the pressure is back to requirements?
I will keep an eye on my pressure and drive the truck around and let you know.
What about my surging, hick-upping problem that occurs every 3 to 5 minutes? Does anyone have a suggestion for that? What sensor it only checked every so often that the intervals seem like 3 to 5 minutes?
Also, has anyone else had problems with their trucks eating up their spark plugs within 3 to 6 months? We are only talking 3 to 4 thousand miles.
Thanks again for you guys help.
Bill Z
I could not find any connection on the ECM indicating oil pressure. It may just be one of those non monitored things.
But I did find that my EGR isn’t working. It would work if the ECM sent it a signal by grounding the gray wire from pin E9 on the ECM. TurboLink doesn’t show that it is getting a signal.
Does anyone know what causes the ECM to start opening the ERG?
Does 'The Ultimate Chip' disable the EGR?
The recording from a base line Typhoon that comes with TurboLink shows that it is most always working on acceleration when not in boost.
Just didn’t know if that was a different problem or adding to the problem that I am having.
The truck still has this surg, hick-up or something every 3 to 5 minutes.
More input please. I will check it all out.
gmcturbo
he's talking about the oil sending unit. it senses oil pressure and cuts fuel pump if too low. it won't show up on a scan tool. i think its just wired directly.
Bill Z
This past week I did a lot to identify and fix my problems. I took non-factory stuff off the truck one at a time and test-drove it. I don’t know if everyone knows this because none of what I found was offered as suggestions. Here is what I found out:
1st. Not the resolution to the problem but with the Ultimate chip in, the ECM doesn’t send an EGR signal. The EGR doesn’t open. Again, this doesn’t seem to be the cause of the bucking problem.
2nd. The truck seems to run just fine without the MSD 6A box. I couldn’t see much difference in performance with it. I will leave it off for 6 months and check the spark plugs for ware.
3rd. The battery connections on this truck is soooooo important. Even a little corrosion can cause problems. My positive connection wasn’t corroded very much but when I cleaned and re tightened it, the problem seemed to have gone away. It was like getting rid of the hick ups. I kept expecting something every 3 to 5 minutes but nothing. It has been 3 days now. The truck is really running and idling smooth.
I think the turning and sudden stopping problem was due to a loose positive battery cable and the battery not being clamped down. It moved and then the battery cable moved.
I re-installed the chip and the problem hasn’t re-occurred (dare I say YET).
My previous cars and trucks were carborated vehicles and this computerized truck is new and fascinating to me.
Thanks to you all for your help and I hope some of what I have found is some help to others.
SeattleSy#1255
Category 5 Conservative
good i hope that the problem is solved...
i can tell you with #1 that the ultimate disables the EGR so that is normal...i believe that T1 15 does NOT disable it, thus probably the best setting for emmissions if you have them.
