IAC problems
socalblue
Hey guys, had a IAC code keep coming out so i replaced it with a new one pulled the ecm b but it still comes back after running the car for a while. When I first start it up its good, but after I go around the block get on it a little and then pull back into my driveway, the idle jumps to ~1000 RPM and doesn't come down.
The IAC is brand new so its prob. not it, what else can it be? Checked plugs looks good wires are new, new silicon vac. hoses. should I check fuel pressure? Where should MAT temps be? IC Pump works...can't figure it out!!
Thanks
socalblue
Re: IAC problems
It idles high in park ~1000...in drive the idle returns to normal ~750.
Anyone have any suggestions?
Thanks.
SBNova
Re: IAC problems
You need to scan the ECM and tel ut how many steps the ECM is commanding. If its commanding "0" steps, then the problem is likely mechanical. If its commanding a high number then its probably ecm, sensor or chip related.
Have you checked and adjusted the TPS?
socalblue
Re: IAC problems
Yes TPS is okay...
When it starts up open loop IAC is high 60ish drops to 40ish
1225-75 RPM desired shows 1250 RPM
26 Hg vac.
S advance moves from 18-24
As it goes closed loop opertaing temp 180F IN PARK, RPM drops to 900-875 RPM
vac same, IAC drops to 0, S advance is at 24.4
BUT...
when I put it in park RPM drops to 675 IAC 0 it idles fine...
SBNova
Re: IAC problems
I guess the engine load in drive is what is bringing the idle down. An IAC of "0" means that the IAC is physically unable to lower the RPM further- but its trying. I'd say you have a vacuum leak somewhere. Try pinching or diconnecting (and capping) some vacuum lines and see what happens. Your base timing could be off too.
SBNova
Re: IAC problems
What is the desired at this point??
SY2932
Administrator
Re: IAC problems
Did you clean where the pintle on the IAC seats when you replaced the old one? More than likely, there will be a fair amount of fouling it there. I have never seen a "clean" one in my travels. It's a pain but the best way to clean it is to remove the throttle body off the truck. IAC valve operation is outlined below:
Be sure to double check for vacuum leaks especially on the throttle body itself.
socalblue
Re: IAC problems
Thanks for the input guys will check it out and revert back, it might be time to go through the throttle body and "rebuild" it.
SBNova
Re: IAC problems
Thats a good point. The IAC position is the "commanded" position but it may not be the actual position. The ECM has no way of knowing the true position, but "0" means its trying to close it.
