Merk said:
There is apparently a procedure to properly install and "set" the IAC motor.
Anyone know it?
1. Jumper A & B terminal on the ALDL
2. Turn key to "on" (do NOT start engine)
3. Go out and listen for IAC "growling" noise. That means its bottomed out. Disconnect the electrical connector.
4. Start engine and idle should be 650 rpm. If its not 650, adjust the idle stop screw until it is. If you've never adjusted it, a metal cap needs to be removed on the TB to access this screw.
5. Turn off engine, reconnect electrical connector on IAC.
6. Start engine, and put the trans in gear......... the idle should quickly go to that set rpm.
