IC Cooler Pump Relay not switching...
Throws
OK... I've replaced the IC pump with a new one, and am trying to get everything squared away with it. I've hotwired the pump, but it doesn't come on in the "key on" position.
I've followed the direction, hotwiring the yellow to ground (position 3 on the relay). I've checked for continuity between yellow and ground, and get a few ohms (.4) of resistance. 5 is the 10A leading from the alternator (red wire). The wire in position 2 (orange) runs to the pump, and that is ok as well (no breaks in the wire when I did a continuity check). The only wire left is the pink/black in position 1. Not sure, but I'm guessing from the ECM.
So, I've checked all my fuses... but when I go KO, I still get no activity out of the pump. If I jumper from red to orange, it works.
HELP!
-P
Chest Rockwell
Re: IC Cooler Pump Relay not switching...
I'm sure it's a dumb question, but did you check the fuse in the holder coming off the alternator?
Throws
Should pink/black have 12v? Currently it's only getting 11.6v
My previous posts about KO is when the engine is OFF. I haven't tried it running, since I assumed just to the RUN position would be ok. I'd like to get the pump running without having the engine running as well.
-P
Throws
I think the pump was drawing too much (since it hadn't been primed). Got it primed, and now it's running like buttah. Just need to shake all the air out.
-P
