Re: IC pump hot wired in low temperatures - problem?
Thanks for your thoughts Dave. I have a Webasto heater, so the starting won't be a problem - and even if it didn't I'm pretty confident it would start with low enough viscosity oil and fresh battery. Not that I'd want to cold start it.
And I have run the Ty in such temps before, in 2006-2008 when I had this one for the first time, without any problems. But I've just added the hot wiring. Maybe I'll disconnect the ground wire to be on the safe side anyway and plug it back for the summer. I don't want to take out the fuse because I'm not sure if I'll remember to put it back again. Forgetting the extra ground wire wont be a big issue.
Everytihng else is stock and working.
You're right that freezing typically is a problem around freezing point - makes sense doesn't it ;-) Not in the dry, colder temperatures.
-20°F-ish temperatures are nothing new to where I live. And if I'm been able to start a car, there hasn't been any problems due to the low temperatures *knocking on wood*. Well, with doors you may have some problems: they may freeze shut or open. Of course you need to use the right oils, good battery, do regular maintenance etc., otherwise it's only you to blame if you run into trouble. Once I washed my Lumina's engine bay with pressure washer just before cold weather and parked the car outside. Was pretty quiet when I was trying to leave for work... Once I had heated up the starter motor with a heater, again running with no problems. Should've let it dry indoors or driven it to warm it up before parking.
I've participated in veteran car winter rally for many years with my '63 Olds Starfire and '49 Olds 98.
Here's some photos from 2012.
The green '49 Olds 98 Club Sedan is mine. The temperature was -17 at that time also. Was able to start from warm garage in the morning, but there's also so called Extreme class where they gather already in the evening before the actual rally, sleep in tents and start up the machines in the morning. They may use hot coal under the engine to heat it up. In the old days when there was no anti-freeze coolant they let out the water for the night and put hot water into the engine before starting up. Alot has changed since then...
