ic pump relay
alaskan
anyone know where it is located in a typhoon? my pump isn't working so i would like to try jumping the relay to eliminate problems just incase. anyone ever use a lightning or cobra pump to replace stock??
Re: ic pump relay
Above the distributor. 2 relays one is for the fuel pump, other is for the IC pump. One with yellow wire (closest to pass side is IC pump)
Re: ic pump relay
Its common that the orignal is dead by now. Check the fuse behind the alternator, the fuse usually pops just before the pump dies.
SY2932
Administrator
Re: ic pump relay
Yep:
And double yep:
"Intercooloer pump fuse location behind alternator. Fuse is in a weather pack connector and the top has to be opened to expose the fuse."
The fuel pump, AC and IC pump relay are interchangeable so you can swap them to see if that's your problem or not. More than likely, the fuse will be blown due to a dead pump as mentioned by dgoodhue. There are several vendors on here who can set you up with a new IC pump if that be the case. Also, if you still have the stock chip, the IC pump will not turn on until the temperature has reached 215 degrees... Most folks hotwire it to be on when the truck is running for this reason. You can get the pump to turn on manually by putting the truck in ALDL mode . All you have to do is put a paper clip between the "A" and "B" terminals with the ignition "ON" without the truck running. This will also allow you to see what trouble codes are stored in the ECM as well. HTH's
NecroWolf
lost marbles member
Re: ic pump relay
even with the stock thermostat these trucks would never see 215 unless you're talkin about thr inlet air temp
alaskan
Re: ic pump relay
the fuse is good and i can hear the pump running in ALDL mode, how do i know it isrunning when it needs to? and is there a way wire the pump to run all the time?
alaskan
Re: ic pump relay
something i just thought of... does the ic pump "get told" to turn on from the engine temp sensor? because my temp gauge doesn't work, so maybe my ic pump just isn't being told to turn on... just a thought
SCWolverine
Re: ic pump relay
Best scenario is the pump "gets told" to turn on by the key (tie the yellow wire TTV8 mntioned to ground). Regardless of engine temp, you ALWAYS want intake air temp to be as low as possible.
Re: ic pump relay
Yep, tie yellow wire to ground, IC pump will run when key is on.
alaskan
Re: ic pump relay
wow. you guys really know your sy-ty's. thanks your are gonna have me haulin ass in no time!!!
tnsyty
Re: ic pump relay
The fuel pump, AC and IC pump relay are interchangeable so you can swap them to see if that's your problem or not. More than likely, the fuse will be blown due to a dead pump as mentioned by dgoodhue. There are several vendors on here who can set you up with a new IC pump if that be the case. Also, if you still have the stock chip, the IC pump will not turn on until the temperature has reached 215 degrees... HTH's
No one shows having an I/C relay in their computers. This is great info from the past. My relay went out and the pump went out the at same time.I put a lightning pump on it last weekend and had to put a switch in place of the relay temporarily.
tnsyty
Re: ic pump relay
FYI:
Turn signals seem to be Blazer FL35 now.
I/C pump relay Duralast 19957.
