carVSsuv
Ok, I have searched and there really isnt a clear answer so I have to ask..
I have had the stock heat exchanger and an ATR aux cooler on my truck with a surflo for a while. I can get good flow in the IC and it stays full. When I am cruising around in 85-95 degree weather my IAT's read 105-115. My question now which I cant seem to find a clear answer on is.. Once I go for a 100MPH pull on stock boost the temps increase to around 150 by the end of the run. What temps do people see??????
I have no EGR hooked up FYI.
I was troubleshoot the system like this
I pulled wanted to do a flow test thru the system. I bypass the pump with the hose and used the other line to drain the system as a flush. I hooked up tunring it on to a high flow setting. I saw that I was vent water into the overflow with an open ended system..HMM.. So knowing that the trucks lower is just old and probably crap. I bypassed it in the setup and now I had no pressure build up and got very good flow.
So I decided to leave it bypassed and do a pass with it that way.. Temps would all do the same. I see people say that their temps do climb above 120 but I guess I dont understand this. Mine dont either if I just do a short burst.. But when its a full 1/4 pull (simulated) it climbs fast but comes back down to normal range very quickly (if that is considered normal)
Any advice would be appreciated. I know the air in the system is going to come up. But lets just pretend that is being dealt with for addition advice.
