Ice box + heat exchanger.
blue83z
Re: Ice box + heat exchanger.
I have one in my sy. Although not a purchased kit, it was professionally done. There is an aluminum box behind the driver rear wheel, and an auxiliary pump with a switch under the dash you can activate with your foot. I can't tell you much else.
atkonkler
Is this your bush?
Another member had a box forsale because his buddy never came back to get it...he's was selling it like $150 obo....
MIXEDBREED
Ya I am always looking for new ways to do stuff. Not sure if you would need it will a alky kit but I guess you never know till someone tries it. I don't have a/c so my truck has extra room for stuff.
They make all different size boxes ect.
MIXEDBREED
They don't cost that much and a whole kit is around the same that I see some guys asking just for a atr upper intercooler by its self. They have liquid to air ones in all different shapes so maybe one would work on the syclone.
Darin
I really feel the biggest problem with the stock intercooler system is the lack of fluid that's in the system. Adding a simple reservoir will keep your temps more consistent, won't heat soak near as quick. Think about what happens when you run low on engine coolant?
Not sure if a larger heat exchanger is needed, but hey, it can't hurt. I feel that part of the reason the dutchty and Sportmachines lower heat exchanger work so well is that it also adds more capacity to the system.
Once I remove my ABS I'll be either buying one of these and modifying it, or make one of my own.
MIXEDBREED
That's what I was thinking. A extra 4-5 gal of coolant would prob help plus the benefit of being able to put ice in the ice box and I bet it will drop the temps pretty good. When my truck gets out of the paint shop I might give this a try.
