Ideas on custom RAM AIR setup, idea's?
0966Sy
Code what?
I am reloctaing my battery and i was thinking of how i could get a Ram Air system to work, true ram air. Not that restricted KB intake kit(i want to get rid of that soon). Well i was thinking of using the passenger side foglight for the intake. But im trying to think of a Box to make or some kind of setup fpr the filter. Any ideas?
It will take alot of plumbing threw where the battery used to be but it will be worth it.
Or i could go all out racer and take out the passenger side headlight, hell ya. That would be some killer ram air.
Erik'
Ian Turgeon
Cascading Inspiration
cut the surround from the headlinght, fill with mesh, cut the metal behind it, and insert box w/filter.
Otherwise, run ducting to botom, cut finder, or cut hood
B
Blake
Guest
I like the headlight idea. You could make a box with one slide out panel. One for fender well use and then another opening behind the headlight. When using at the track, pop out the headlight, slide in the fender panel, and you've got good ram air(that flat front is finally good for something). I think most tracks just want at least one working light on the car. I would open the sheet metal behind the headlight to 3" or 4" diameter. Totally stealth when headlight is in.
Blake
myclone
On 2002-01-14 17:25, Mybad wrote:
What does he use the brass fitting on the inlet hose for?
For the PCV connection port when the factory cross over is removed would be my guess.
badnewz
What I did for ram air was, I went out and bought a griffen radiator and located it toward the driver side about six inches, and moved the a/c condenser over the same amount. This allowed me to drill a 4" hole with a hole saw thru the radiatior support next to the headlight behind the grill in the air stream. Then I bought an HKS mushroom style air filter and mounted it between the grill and the radiator support. I used a 4" alum. tube to connect to the turbo. (PTE 70 with 4" inlet). I had to fab up a radiator hold down on the top.(not that big of a deal) I used a b+m supercooler for a replacement oil cooler and used an electric fan from a grand national. I used cool flex radiator hoses.
This was alot of work but it could be done with garage tools. It is a true ram air, getting fresh air from the front of the truck, and the truck cruises a 168 deg. This is really hidden and if you get a black air filter element you would never see it behind the grill.
Mike B
St.Clair Shores, MI
badnewz
"just so you know, those HKS mushroom filters are junk."
The filter material seemed kind of restrictive (sponge?). I figured it would be good enough for driving around, but if I got into some serious action I could pop the filter element out. I hope it doesn't fall apart on me and go into the turbo.
Mike B
St.Clair Shores, MI
