Idiling problem with no codes!
Grimgrak
Finnally fixed all my codes yet i've still got this annoying rough idle where the truck runs really strong on start up but 2 minutes later it struggles like a 80 year old man with asthma. From that point on the truck has to warm up before it will idle properly and will die if you try to put it in gear while it's idling funny. I've already replaced the IAC what else could be left to cause this problem!??! :rant:
Andreas
Re: Idiling problem with no codes!
Seems its a little rich overall
AFPR?
What tune up did you do? Cap/rotor/cables/plugs?
New O2 sensor?
Had the same symptoms 2 years ago. My dist was so bad. Put in a new dist and IAC and problem solved.
Check timing.
Reset the ECM.
BTW I spend the summers in the Vancouver area. Have only seen one syty before in Van area (Odium's at a parklot in Whistler)
Grimgrak
New cap/rotor/plugs/wires Truck has 70k on it not sure if new o2 sensor would help as it's still fairly responsive according to the voltmeter. It does seem to have some sort of aftermarket AFPR I assume these trucks did not have one stock?
AFPR?
New O2 sensor?
Check timing.
Reset the ECM.
Andreas
Nope no AFPR stock.
If you have the possibility to swap the MAP sensor from another truck try that.
That cleared my probs with my truck.
Also, I would check the temp sensor on the driverside head and the tempsensor by the thermostat. If you got Chiltons maintance book it shown how to.
If not, I can scan the pages.
