Idle flair at cold startup
SBNova
I have had an idle flair at cold startup since Ive owned this truck. It usually starts and the idle goes to +/- 1300 rpm, and when its cold a little higher. Last week with the colder temps we had it would run at 15-1600 for 10-20 seconds before calming down. That was pretty annoying, so I decided to take a look at it.
I ended up changing the table labeled "Initial spark ramped out vs. coolant temp", (F46)
I changed the 32 deg C field to 1.41 degrees timing, and the 08 deg C field to 3.87 degrees of timing, which basically halved the original settings. Wow what a difference! If figures that since Ive done it, we havent had many cold mornings to truly compare, but it definately starts and runs at a much more reasonable idle speed now.
I just thought I would share my findings. I hope someone else will find it usefull, and report back as to whether or not it worked for you.
