i have been trying to hunt this problem down since i bought this thing. at idle rpms hunt and tach flutter at idle. wot seems ok. it has a little miss a part throttle. i have changed all vac lines, throttle body, plugs, cap, rotor, coil, map sensor, wires (msd), timing is right on, also flow tested / cleaned injectors,and intake gaskets. when i disconnect the wire to set timing the timing mark is rock solid every time. when i reconnect the wire it starts jumping around a couple of degrees. even with the wire disconnected it idles funny. i have yet to check iac counts after throttle body swap but they were in the 0-8 range. no codes have popped up ever while ive had this truck. does anyone have any ideas? the truck no longer dies when i put it into gear but the rpm's go pretty low and it sounds like it might die now. i'm thinking something in the computer/wiring harness...any help PLEASE!!! i'm almost ready to sell this thing it has given me nothing but problems! BTW the exhaust is sputters every couple seconds like a wire is arching out of something. PLEASE!
