Idle issue on Code 59
black cat
Been tuning using Code 59 for two weeks, today my idle went up to 1300 and would not quit. finally found the table, it was the desired table while in ALDL mode, it was set at 1250. Can't figure out why it needed to be at 1250, at 850 everything is ok. Why would it have been set at 1250? This is a bin from code 59, just trying to iron out bugs, Thanks.
wildphil
I Love My Ty's
Re: Idle issue on Code 59
I'm not familiar with that table. I haven't ever used it for idle. I will look and see what mine is set at.
wildphil
I Love My Ty's
That table is set at 1250 on my bin. As far as I know we don't really adjust that table.
The tables we use for adjusting idle.Now I could be wrong. But I think this is correct.
In the Tables/Functions area scroll down to idle.
table F13 Desired idle vs battery voltage. Whatever RPM this is set at your engine will not idle lower than this. I set this lower than I set my park/neutral and the drive idles. By doing this I can adjust the idle as needed.
Next I adjust F19 desired idle RPM vs coolant for park/neutral
Then f18 desired RPM idle vs coolant for drive. I set this about 25 RPM higher than the RPM setting that I put in F19 for park/neutral.
Again pretty sure this is correct. If I am wrong please someone post.
nallj92
its aldl mode, on the aldl cable theres a switch, it may have got bumped. I am guilty of bumping mine once and couldn't figure out my high idle. This is referring to a moates xtreme aldl cable btw.
Yep your in ALDL mode, you dont WANT to be there, Probably cable as mentioned.
black cat
sorry bout the late response. i.m glad i posted this cause that was it. thks pat
