Idle Vacuum readings
What is a normal for idle vacuum, I usually get 20". I know this sounds like a stupid question, but I just found out my other car has low vacuum which I hope has been a root of its problems.
sytyguy
Moderated User
Even with the 412 cam I get good vac readings. Here are some examples:
Idle (P/N - 800rpm)- 18"
60mph (OD - 1800 rpm) - 15"
70mph (OD - 2000 rpm) - 12"
80mph (OD - 2200 rpm) - 10"
Vac should be rock steady at idle.
HTHs
Michael
InvisiBill
White97SVT
I get 20 at idle. Then when i am on the highway rolling along at 70 if back off the gas it will read like 24-25. How come you get more vacum when you are on the highway at like 70 and let off.
I get less though when i am just riding around on the highway with cruise control at about 70. What do you guys get when you are ridding around at about 70 or so.
Lynn D. Brown
Because U have closed the throttle plate and R seeing the full Vac of the engine. The more U open ther throttle, conversely, the lower the Vac gets, because U R letting in air and Fuel to "fill" the Vacuum.
