Re: idleing?
check solinoid and vac hookups for the boost. A disconnected vac could cause bad idle and low boost. Sure its 7lbs. dont go by stock guage. Bad idle could be a ton of things. Most common are:
vac line, iac, egr, tps, bad cap,rotor, wires or plugs(type or gap).
