Idler arm rubbing on crossover?
0966Sy
Code what?
My Idler arm was shot on my Typhoon(102k) I replaced it with Napa part# 18809 $23. My oem Idler was rubbing the crossover pipe so bad it had worn a notch in the arm on the Idler. The crossover pipe was not dented or damaged :eek: . I thought that the oem idler had a notch finished into the arm to clear the crossover at full left wheel lock. Well i guess im wrong, i came home and my Syclones Idler did NOT have a notch nor was it touching at wheel lock. It was solid(58k)
Well that clears that up, the the NEW napa Idler just rubbed worse and actually would move the crossover causeing stress on the manifolds. Well the bolt holes on the frame that hold the idler have an up and down adjustment. This rubbing was cuased with the bolts at the top adjustment. I corrected the rubbing by moving the idler to the lower bolt hole positions, thus changing my TOE hardcore. I adjusted my TOE back with a thrust alignment and viola it's done no more rubbing on the crossover.
My motor mounts are good and i have no clue why the oem Idler was rubbing (so bad as if it had done it from the assembly line) Anyway it was shot and had about an half inch of flex on the ball joint. But it only would rub at full left wheel lock. Just thought i would share my thoughts to help anyone out thier that has an Idler arm rubbing on the stock or ATR/KB crossover.
ItsMyTy
Life is beter at 25 PSI
did you try taking the crossover pipe loose, pushing the crossover up and tightening the crossover nuts?
i had to do this on mine to correct the same problem.
