syclownz
Here's to a shot in the dark.
I read on here somewhere someone rewired their ignition module to ecm and it turned out to be a great idea. Well, I thought I'd give it a try since I keep on getting tach surge or flutter and est code from time to time. Idle will be at 800 or so rpms and then it will drop to 500 then jump up to 1500 rpms. You would barely notice it if you weren't looking at the tach.
I bought the new 4 pin connector from the chevy dealership and rewired the whole thing. took it on a test drive and it was a beautiful thing. No glitches or anything. I start to pull in and the truck dies on me. No warning-just dies. I try and start it but nothing. Has full cranking power just no start. I notice the tach isn't moving while cranking so I go to 2 different autozones and they both tell me the ignition module is good. Wtf! Once again I thought if there is no tach signal then the ign. module is at fault.
I get home and put the ign. module back on and try some stuff before cranking again. Check to make sure I'm getting spark from msd coil >yes and check #6 plug wire (because it is the closest) for spark>yes. While checking for spark on the #6 while cranking the truck fires right up before I could even turn the key back.
Put everything back and try to start truck and everything is fine again for now. I'm affraid to drive it because what if it turns off on me in the middle of the street again? I got lucky my neighbor was home to help me push it UP my driveway.
Did I miss anything when I rewired the 4 wires at the ignition module to the ecm or has this happened to someone before? I did> white wire to pin 8 #423 D
purple/white to pin 8 #430 C
tan/black to pin 7 #424 B
black/red to pin 9 #453 A as per "vault" ecm schematics.
