Ignition voltage down when RPMs up!?!?
JoeLutz
I'm battling some knock retard and I was looking at a couple datamaster files and noticed that my ignition voltage is usually arround 13.1-13.3v, but when I get on it and the RPMs goe above arround 3500, the voltage drops down into the 12.6-12.8v region.
I thought ususally when the engine is turning faster, it produced more volts because the alternator is turning faster. Could it be a regulator problem? Or is it not enough to worry about?
Tooky
Serious about performance
Joe mine is equally strange. I think I have an underdrive pulley on my alternator so perhaps the voltage is not enough to keep the fuel pump running fast to keep the truck from going lean right? My truck has knock retard and low O2 volts which may indicate a lean condition. So you would think at higher RPMs where more fuel is required, it would definitely knock the most. You might think that but you'd be totally wrong! Get this, the few times my truck has gone to 0.0 knock retard have always been at the top of 3rd gear above 4300 RPM!! How can that be? And to make things more confusing, the only other time my KR went to 0.0 was right after the shift to 4th (OD) around 3600 RPM. Makes no sense to me..
JoeLutz
Josh,
First, thanks for bringing the voltage to my attention! I would have not noticed it otherwise.
I am looking at your run now and plotting everything I can think of against the knock retard, and I haven't seen anything yet. However, I have noticed a difference in your knock retard an mine. It seems like your knock retard comes and goes in cycles and is decreasing in amplitude as your speed and mabey RPM increases. wierd. Whereas mine seems to slowly increase or stay arround the same amount and not fluctuate so much. Mabey you have false knock.
jwaller
Evil Genius/SyTy Guru
this is a common problem with syty's....you MUST check your actual system voltage with a voltmeter in the cig lighter during a run...you may want to bring a friend along to help. I have noticed this on many trucks and some have larger alternators and some don't. it doesnt seem to make any sence. It appears that the ECM signal that is coming through to the ALDL is being dropped by the ECM when under a load condition. I don't think a larger alt would help. I think the only way to fix this is to run a larger Batt wire to the ECM.
mrweelr
I have the same problem. My truck shows 13.4-13.6v at idle in Datamaster but at WOT (max boost) it shows 12.7-12.9v. I'm inclined to upgrade the alternator to a high amp unit but based on jwaller's comments it sounds like a waste of money. What's disturbing is that BG says having 13.6v at WOT will help performance tremendously. If anyone figures out how to fix this please post it here.
jwaller
it's a strange problem to mess with....you have to check your actual system voltage by using a voltmeter....check it at the cig lighter or something..if your system voltage is going down then I would suggest a new alt or a larger unit.
mrweelr
Why do I need to check it through the cigarette lighter? Are you saying that the ECM readings might be inaccurate? If you look at my other post in here about the Optima battery, you'll see that I'm considering purchasing a Powermaster 140amp alternator for $155. Do you think it will help? Numerous others in here have indicated that they too have low volts at WOT so I'd be willing to be a guinea pig of sorts.
mrweelr
Screw it, I just ordered the 140amp Powermaster PN PWM-47861. If this doesn't get those volts up at WOT I'm out of ideas. I'll post an update after I get this thing installed.
jwaller
cool....I'd like to hear if that fixs it...the ECM does not take a direct batt reading..it comes from the back of the ALT.....so the reading is what you see after the ECM uses power..so it's low...one way to fix this is to increase the size of the wire going to the ECM..but a larger ALT couldnt hurt....do tell if it fixes it :smile: :grin:
JoeLutz
Its been my experience that a weak alternator causes the system voltage to be lower at idle, not higher rpms.
I have developed a theory. (OH NO):) Since the ECM drives the injectors, it would make sense that the ECM would pull a lot more current at higher engine loads because the injector duty cycle is at or near max. If the ECM pulls more current, that means any electrical resistance in circuit supplying power to the ECM would cause a voltage drop, meaning the ECM would recieve less voltage at the higher load conditions regardless of the system voltage. I agree jwaller, a larger BATT wire to the ECM may help. However, judging by the wiring diagrams, my guess would be that the greatest resistance in the power suppling circuit would be in the fuse box. Mabey all we need to do is put in a larger fuse with less resistance, or clean and tighten all the electrical connections at the fuse box like where the fuse plugs in. I don't feel real safe with just putting in a bigger fuse though. I may try to take some voltage drop readings coming out of the fuse box and at the ECM.
Just my .02 cent idea.
