Important FAST FYI....
smeagol
I've seen this on many instances, fortunately I was aware of it and usually only happens when I'm doing drivability tuning.
I learned don't do ANY fast keystrokes etc in the Windows version. This is the reason I was hunting for a fresh DOS version a bit ago. The windows software is about only useful for datalogging and mild tuning (aka not in the vehicle, seat of the pants stuff).
Real PITA, and drove me nuts trying to figure out what the F was going wrong with a vehicle when this issue was to blame :evil:
I've also seen a truck run real weird when the com port connection was physically half there. Disconnected, restarted the truck, all good... :evil:
100in6
100in6
brian,
would it be any help to you if i sent you my fast disc. i'm pretty sure mine is ok and you could use it if you want. just let me know
les
smeagol
Thanks Les, but I've since located some OEM FAST-DOS disks, now if I have any problems it will be connection related. The WinSP is a bit more flexible than the DOS version as far as com ports is concerned.
Windedv6
Ty n 10s
I have on several occaisions had the windows version go into open loop on it's own. The only way to get it to stay in closed loop ater it does that is to get out of the program an open it up again. Did it a couple of times at the track. Didn't hurt anything as my target and actual fuel were almost on top of each other. I would have been up a creek if something went wrong.
Something that Brian has warned many of us about....our double intank pumps. I blew a fuse in one of my pumps and luckily I had the FAST program correction tables set to add an additional 25% fuel if called for. Even at 25% I still hit 13.6 afr....(a little scary) That correction only works in closed loop. Had the program decided to kick out of closed loop on that run there would have been a big bang. I now double check my tables every run.
John
