tbauer03
TRBOBOX
Ok i got my truck running really well right now using a 3 bar chip and fp set at 45. I did a 1/4 mile run at 13.6 according to g tech with 0 knock the whole time. The only thing is my boost was very inconsistent throughout 1st and 2nd gear it started to level out at about 16 psi in 3rd.
In first gear it started about 10lbs then went up to 13.4 then shifted and i got a brief spike to 14.6 then down to 10.9 about 1/2 way through 2nd then by the end of 2nd it climbed to 15.5 i got another brief spike to 17.1 on the shift but then it fell down to 11.1 then it climbed and held steady around 16 psi the rest of the run.
I am running pretty rich about 990-1010 02mv throughout the run and that may have something to do with it but i am thinking it is the stockwaste gate. I am pretty sure an external wastegate should correct this and make my boost less like a rollercoaster. But i was really wondering if there were anyother solutions for this problem to try before i do an external wastegate.
